Using C++ Builder
techdesk
STMCubeIDE seems to give endless problems. Since the MX can generate c++ code what is the possibility of using all the generated files in C++ Builder? If This is possible, which files should I look for? Has anyone tried this before or will we just have to be stuck with STMCubeIDE.
I do note that many tutorials using  STMCubeMX usually have their code generated using other toolchains and not the STMCubeIDE.
Could someone shed some light on this matter?
10 REPLIES 10
techdesk
Ok I managed to get STMcubeIDE ver 1.15 to work on Windows 7.
I had to download the zip file from the patch site  https://www.st.com/en/embedded-software/stm32cubef4.html
I simply just extracted the zipfile and over wrote the files in the repository on my pc.
No other patches are required
Thank you all
