Unable to transmit the data to EC25 Modem with STM32F407VG
  • June 15, 2024
  • 3 replies
  • 1678 views
I currently working on the EC25 Modem using STM32F407VG support for CDC, where I am able to get all the enumerated values of Device Descriptors, Configuration descriptor and Interfaces but unable to transmit the data and get the response back, and I have used the CDC example code of STM32.So can someone guide me regarding this issue.
AT Command Used: "AT\r\n"
@STea
@Danish1
    Andrew Neil
    @Shashanksd07 wrote:
    the EC25 Modem
    You mean this: https://www.quectel.com/product/lte-ec25-series/ ?
    That seems to be just a module? So how do you have it connected to your STM32F407VG ?
    Have you verified that you can communicate with it from a PC?
    I have integrated the EC25 on the mini pcie evb v1.02 kit and then using USB cable to STM controller and I have checked it via serial (putty) but not with STM CDC example.
    Andrew Neil
    You mean your "EC25 on the mini pcie evb v1.02 kit" does work when connected to a PC?
    So does your STM32F407VG work with any other USB CDC devices?
