The program pauses and refuses to run after access multiple breakpoints access warning (handle_vCont_t, Thread already stopped)
Options
2020-04-12 05:37 AM
I got with the CUBE IDE the following problem, at some random point in the program, the Debugger halts and throws the following error:
It occurs several times a weak and I didn't found a solution to this
Labels:
- Labels:
DEBUG
STM32CubeIDE
1 REPLY 1
Options
2021-03-19 06:06 AM
Hi Aish,
I'm experiencing the very same problem and can't find a cause. Since some time has passed, I'm wondering if you have found a solution or some mitigation. Thank you.
