Task failed while connect to the server..
I am working on STM32h753zi board i have one main task with the size of 3K inside that i was calling 6 tasks.
Task 1 - 5K Normal priority
Task 2 - 1K Normal priority
Task 3 - 2K Normal priority
Task 4 - 2K Normal priority
Task 5 - 1K Normal priority
Task 6 - 3K Normal priority
Problem: If comment out one or two tasks then only other tasks are running otherwise some tasks are failed to connect.
example: I comment out task 5,6 then task 3,4 is working properly.
I comment out task 4 then task 3 is working properly.
->I am not facing any hardfault handler or malloc issues.
->There is no global variables are there.
I dont know how to fix this issue and i dont know how find the reason. Please give your guidance thankyou.
