Stm32h753i-eval2 USB Host FS
Options
2024-10-10 6:43 AM
I need help generating an .IOC file through the cube generator. What I need is USB Host FS. I'm having trouble getting it to work, specifically, there's no voltage on the VBUS output.
I want to mention that I was able to create a USB Host HS that works and outputs voltage.
Thank you!
Itzik
10 REPLIES 10
Options
2024-11-01 1:23 AM
Thank you all for your help!!
I wasn't able to create an IOC file such that, but I solved it by:
1) Using a ready example that works
2) Use our CUSTOM BOARD and generate such IOC file worked.
I really appreciate your assistance!
- « Previous
- 1
- 2
- Next »
