2025-08-19 3:31 AM
Hallo, I'm facing with a problem of IDE v.1.18.1 crash starting from early today (OS Windows 11).
This version has been being used al least 3-4 months , and even yesterday everything worked fine.
Once I try to open IDE, it pretends to look for some updates and crashes almost immediately.
There are no spaces in paths; I didn't make any changes at all.
Does anyone has a clue, what could go wrong?
I still can run IDE 1.12.1, but i cannot update it to ver. 1.18.1.
2025-08-19 4:29 AM
Hallo Souhaib,
thanks a lot for Your prompt reply!
As You advised,I tried to deal with the lastest ver 1.19.0 and noticed the same issue.
The deletion of .stm32cufinder, .stm32cubemx, .stm32cubeide and .stm32cube did really help.
2025-08-19 3:39 AM - edited 2025-08-19 3:39 AM
Hello @DariaLav
Could you try installing CubeIDE V1.19.0? Otherwise, try these steps,
- Close STM32CubeIDE
- Delete all those files from your PC: .stm32cufinder, .stm32cubemx, .stm32cubeide and .stm32cube
- Restart the STM32CubeIDE
BR
Souhaib
2025-08-19 4:29 AM
Hallo Souhaib,
