STM32CubeIDE crashes on opening 'Software Packs'
2025-05-26 6:27 AM
Hello All
I'm using STM32CubeIDE 1.18.1 on a Windows 11 (10.0.26100) virtual machine through VirtualBox (7.1.8).
I've been able to create a project for my board and generate code, however when I go to the software packs, it causes the IDE to consistently crash.
I have so far attempted to no success:
- Reinstalled the software
- Updating my java installation
- Using a different drive (C:/ instead of a shared Z:/ drive)
My .metadata/.log is as follows - repeated many times:
(I have also attempted to install STM32CubeMX but have been unsuccessful, probably unrelated)
Does anyone have any ideas or solutions? - A quick scan of the forum didn't come up with anything
My local installation of the IDE works (and gives the same .log errors) however that isn't a viable solution for me in the long term.
Thanks in advance.
STM32CubeIDE
2025-06-02 1:48 AM
Given that the software simply does not work with the Windows 11 environment stated above. For anyone following along I have resolved my issue by the following:
Changed the VM to Windows 10 (Windows 10 Pro, 19045.4529). Using the software:
- Visual Studio Code 1.100.2
- STM32Cube for Visual Studio Code
- STM32CubeMX 6.14.1
- STM32CubeCLT 1.18.0
- STMCUFinder 6.1.0
2025-05-27 1:05 AM
Hello @dbit
Let's try the following steps :
1- Check Virtual Machine configuration: Ensure that your virtual machine has sufficient resources allocated (CPU, RAM) to run STM32CubeIDE smoothly.
2- Verify that the virtual machine's network settings allow it to access the internet, as this might be necessary for downloading software packs.
3- Try to follow the steps mentioned in this Article How to set the network connection parameters for STM32CubeIDE and STM32CubeMX
4- Try creating a new workspace : New-->Switch workspace-->other-->Create a new workspace
If the problem persist , manually download the software packs from the STMicroelectronics website and install them offline. This can sometimes bypass issues related to network or IDE settings.
I will be waiting for your feedback.
THX
Ghofrane
2025-05-27 2:01 AM
Thanks for getting back to me.
- The machine should have enough to handle the IDE, 16GB RAM, plenty disc space.
- I have had to disable proxys for the IDE to connect to the internet - this is confirmed by my ST account connection. The crash happens irrespective of if the connection is active or not.
- I can confirm that I have followed those steps.
- New workspace still gets the crash.
I have downloaded a package to try and load it 'offline' using the {Help -> Configuration Tool -> Manage Embedded Software Packages} and adding from local. Fortunately I can also download packs from this menu, which is a step forward, thank you.
Unfortunately my issue is not resolved as when I attempt to use or configure the package the 'Software Packs Component Selector' screen is brought up, thus crashing the program.
Do you know why this would be happening?
Thanks.
2025-06-02 1:48 AM
- STMCUFinder 6.1.0
