2019-10-17 6:00 AM
There is no stm32cubeIDE section so I post it here.
I found another bug that isn't mentioned on the known issues and I found no bug tracker to post this issue
When you re-generate code using the integrated cubemx, all included folders (in properties > paths and symbols > includes) as well as the sources locations get deleted and therefore, the project doesn't compile anymore.
Bertrand
