2023-07-12 12:07 AM
I have just updated the IDE from 1.12.1 and updated my project as requested but I have encountered an issue when compiling.
I get 3 errors on previously compiling source code. as follows
Can you help with what might be the problem?
PhilW
2024-01-26 1:10 AM
you should add
__attribute__((weak)) void _gettimeofday(void){}
as well.
