2024-07-25 12:49 AM - edited 2024-07-25 12:51 AM
For example there would be a file called "common.h" containing a single line no #include or anything:
2024-07-25 1:33 AM
2024-07-25 1:33 AM
2024-07-25 1:46 AM
Thank you so much!
This was really bothering me that I couldn't figure out what it was. It does indeed seem to be symlinks because I cloned the repository into windows as is and it runs just fine if I do it in WSL instead.
