2025-08-13 2:30 PM
Running STM32CubeIDE versions 1.18.1 and 1.19.0
i
static char *Audio3D[] = { // Main Settings display
"THERE ARE 15 VOLUME ",
IDE version 1.18.1 displays a 21 character line of code with the quotes one ontop of the other.
static char *Temp2D[] = {
" TEMPERATURE ",
" CELSIUS ",
" FAHRENHEIT "
IDE version 1.19.0 displays a 21 character line of code with the quotes not lined up
Makes it extremely hard to see if hundreds of lines of code are all 21 characters.
" TEMPERATURE ",
" CELSIUS ",
" FAHRENHEIT "
2025-08-13 3:41 PM
> quotes not lined up
Maybe a screenshot would be more descriptive here, yes?
Check that the file is pure UTF-8 characters and encoding is set correctly. Font is monospaced, should display the file contents accurately.
2025-08-15 5:58 AM
Please tell me How to set encoding. How to make fonts be monospaced.
2025-08-15 6:04 AM - edited 2025-08-19 1:50 AM
@JBonn wrote:Please tell me How to set encoding. How to make fonts be monospaced.
Properties->Resource->Text File encoding (then set to UTF-8)
Preference->general->Appearance->Colors and Fonts->C/C++/Editor
Please format your code in your posts: https://community.st.com/t5/community-guidelines/how-to-write-your-question-to-maximize-your-chances-to-find-a/ta-p/575228
2025-08-15 6:57 AM
They're monospaced by default. If you have weird characters, that's the problem. Impossible to know what's going on here as you didn't really provide enough detail.
