SOLVED: IS BUG. STM32f4 custom hid generated code shows up as "STMicroelectronics LED badge -- mini LED display -- 11x44". where is this configuration fault?
Dvan .8
As far as i could find it should show up as a mouse and I should only have to edit the report descriptor in usbd_custom_hid_if.c.
Dvan .8
found the solution. In usbd_desc.c USBD_PID_FS is set to 22352. This needs to be set to 17185 for custom hid
Dvan .8
