SDIO stopped working after upgrading CubeIDE from 1.10.1 to 1.12.0 CPU is STM32F407VGT6 SDIO mode is SD 4bit Wide Bus FatFs unused Error in HAL_SD_ConfigWideBusOperation(&hsd, SDIO_BUS_WIDE_4B)
magi
KDJEM.1
Hello @克徳 高間木​ and welcome to the Community :) ,
What do you mean by 'Error in HAL_SD_ConfigWideBusOperation(&hsd, SDIO_BUS_WIDE_4B)'? A debugging error?
Could you please share what errors did you found?
Kaouthar
magi
Hello
Return value of HAL_SD_ConfigWideBusOperation(&hsd, SDIO_BUS_WIDE_4B) becomes HAL_ERROR
I attach the return value of hsd
The software was working fine before the update.
Also, if you recreate the same software with 1.10.0, it will work normally.
