SD card on STM32F407VET6 Black board Project
Aabc
I'm working on a project involving the SD card on the STM32F407VET6 Black board Project. I would greatly appreciate your expertise and guidance in connecting and writing the necessary code to get the stepper motor running.
If anyone has experience with this setup or can share sample code and wiring diagrams, it would be incredibly helpful. Your insights would make a significant difference in advancing my project.
Thank you in advance for your support!
mƎALLEm
You can inspire from the example provided in the STM32CubeF4 on this link.
Peter BENSCH
...if the board uses an genuine STM32F407VET6, which is often not the case, so please double-check that.
Your board is not from STMicroelectronics, but the question is essentially identical to this question.
/Peter
