running headless-build.bat in azure devops using a build agent
ptiwa.1
hi,
i am trying to run this headless-build batch file in azure devops as CI pipeline set up (my agent is local build agent)
i am facing error - project name not found
please check my below syntax and help me
cd C:\ST\STM32CubeIDE_1.3.0\STM32CubeIDE
call .\headless-build.bat -project KoolKey_2.0 -workspace C:/myworkspace -build -console
above 2 lines of code i have as Compile.bat file and running this in azure devops
below error i am getting
ptiwa.1
Error message attached
Fabster
Hey
Maybe that doesn't help in your specific case, but i saw your thread when searching for existing docker images to build STM32 projects in Azure DevOps and it may help somebody. Since i didn't found any working solution for my case, i built a docker image with the complete STM32CubeIDE in it. You can find it here with some working yaml examples for Azure DevOps.
