Project imported from TouchGFX but not able to debug for board STM32H745I - DISCO
‎2023-11-09 2:52 AM
Board : STM32H745I - DISCO
Cubeide : v.1.13.2
TouchGFX : v4.22.1 Designer
STM32H745I - DISCO as it is dual core m4 and m7
1st i did build and debugging for m4 processor. It is successful.
2nly done with building for m7 processor.It is successful
But while debugging the m7 i am facing following issue ??????
please help me with this .
Error in final launch sequence:
Failed to execute MI command:
load C:\\TouchGFXProjects\\11092023\\STM32CubeIDE\\CM7\\Debug\\STM32H745I_DISCO_CM7.elf
Error message from debugger back end:
Load failed
Load failed
Load failed
Load failed
- Labels:
STM32CubeIDE
‎2023-11-10 10:50 AM - edited ‎2023-11-10 10:51 AM
Hello Chaitanya1997
Your case has been routed and your question will be further addressed through the online support system.
Kind Regards
Joe WILLIAMS
STMicro Support
Hello Chaitanya1997
Kind Regards
Joe WILLIAMS
STMicro Support
‎2025-03-07 2:10 AM
Hello @Joe WILLIAMS
I have the same issue than Chaitanya.
I have created a simple TouchGFX project for the board STM32H745I-DISCO. I can run the project from TouchGFX 4.25.0. I have imported the project to CubeIDE 1.17.0. I can compile both CM4 and CM7, I can run CM4 but when runing or debbuging CM7 the error Failed to execute MI command appears.
Please, do you know a solution for that?
Thank you.
‎2025-03-13 4:49 AM
in my case the Mi error was because I needed to load an external loadar beacuse de QUADSPI flash.
In Run configurations -> Debugger.
Add external debugger -> C:\Program Files\STMicroelectronics\STM32Cube\STM32CubeProgrammer\bin\ExternalLoader\MT25TL01G_STM32H745I-DISCO.stldr
Regards.
