JTAG Daisy Chain
ABhuv.1
Hello All,
I am in the process of designing a circuit with four microcontrollers in Daisy chain. I would like to program and debug them via one JTAG port, hence will be daisy chaining them.
Which one of the programmers can do this?. I have used ST-Link-V2, but this cannot programm multiple chips in a daisy chain.
Peter BENSCH
Welcome, @ABhuv.1​, to the community!
The ST-LINK/V2 is only a simple debugger for SWD (Serial Wire Debugging), for JTAG debugging you need a JTAG debugger, such as the J-LINK. A similar problem has been discussed in the Segger forum, maybe this will help you?
/Peter
4 REPLIES 4
Peter BENSCH
/Peter
ABhuv.1
HI,
To be more specific, is there a programmer available from STM which can program JTAG chains?
Is the J-Link programmer compatible with Atollic Studio? I cant find any definitive Info on this. From the earlier thread, its isnot clear what IDE was used.
With Regards,
Adi
Hello Adi,
Depends what you mean by "From STM", ST-LINK/V2 which is developed by ST can't do it, just as Peter mentioned. However, both STM32CubeIDE and TrueSTUDIO supports J-LINK.
Keep in mind that TrueSTUDIO is deprecated and I would suggest using STM32CubeIDE.
ABhuv.1
Hi Markus,
Thanks for the confirmation. Ill use the Jlink with STM32CubeIDE
With regards,
Adi
