Is it possible to start an STLink serial terminal from within the IDE?
‎2021-05-15 6:12 PM
I can manually start Tera Term and connect Serially, but I cannot find how to do this from within the IDE. Is this possible? Maybe a project option that needs enabled?
Using STM32CubeIDE 1.6
- Labels:
STM32CubeIDE
‎2021-05-15 10:36 PM
I just found it. If you click enough buttons (I could not find where the info is in help).
The info I found online showed the icon for the 'Display Selected Console', so it added a bit of a twist.
Here is how to invoke:
- Start a Debug session.
- Click on the Open Console button.
- Select 'Command Shell Console'.
- Set Connection Type: 'Serial Port'
- Click new and give some name, e.g., STLINK_Serial (this name will be available on subsequent access)
- Set Encoding to UTF-8
- Click OK to display output
Cheers,
Derek
Cheers,
Derek
