I2C pins
‎2023-06-22 10:42 PM
I used STM32L031K6 Nucleo board.
When I Enable I2C it select by default PA10(SDA) & PA9(SCL) pins for Communication it not work, Then I change Pins for I2C PB7(SDA) & PB6(SCL) it work well.
so any additional configurations need for use PA10 & PA9 pins ?
‎2023-06-23 5:58 AM
Hi @Rushit
No additionnal Configuration required. Can you confirm me that your GPIOs are in pull up mode?
Diane
‎2023-06-25 11:32 PM - edited ‎2023-06-25 11:33 PM
‎2023-06-26 1:19 AM
‎2023-06-26 2:28 AM
is it any problem in PA10 & PA9 pins ?
