I'm using STM32F072B-DISCO board, wanted to see data on serial monitor but can't enable SWV in STMcubeIDE, any suggestions?
SPati.9
Markus GIRDLAND
Hello there!
SWV tracing does not work with Cortex-M0, that is why the button to enable SWV is greyed out.
You could try to use Live Expressions if you want to check a specific variable for example. If you specifically need SWV then you would need to use another board.
Markus GIRDLAND
Hello there!
SPati.9
Thanks Markus,
I've used the following tutorial on live expressions :
https://www.youtube.com/watch?v=Nyml66k_Ppk&ab_channel=RADAS
This works fine.
