How to make a variable float to const float
methee_c
Dear All,
I compile a program with cube ide and would like to know how the float variable is const float.
sample is.
float a
const float  b
b = a;
BR,
Methee
12 REPLIES 12
And I can't edit or pull code from a screen shot/bitmap.
Make a structure you're configuration items live in.
Create routines to read, write and validate this structure you can place in FLASH or EEPROM
FOO foo = { 0 };
void InitFoo(FOO *foo, EEPROM *eeprom)
  foo->donkeys = 12;
  foo->freqHz = eeprom->freqHz;
  foo->speedRPM = eeprom->speedRPM;
I will keep trying,
My project needs to set parameters from a keypad.
Ok,Thanks  you
