How to integrate Scons build system in STM32CubeIDE?
Kunal_Atom
I tried to do it the same way it is for Eclipse but it is not detecting the SConstruct or taking the Python Library
4 REPLIES 4
Pavel A.
CubeIDE is Eclipse. How it works in your Eclipse? Does your scons run on Jython included in Eclipse, or on external CPython?
-- pa
Hi Pavel, thanks for responding.
  • My scons runs on normal Python using PyDev plugin in eclipse.
  • I tried the same set of settings I did in eclipse but working there in eclipse.
Then probably it can work as "makefile" type project. Instead of "make" specify your script as the build command.
-- pa
yeap I did that, still not accepting
