SVerm.3
How to convert each character of string to hex string in STM32F4 Discovery Board?
  • May 28, 2021
  • 9 replies
  • 6521 views
I am using STM32CUBEIDE and want to convert each character of string to Hex string in STM32F4 Discovery Board, as I want to mask my string and process masked data. Please help me asap.
Best answer by Piranha
Most likely the author doesn't need any HEX conversion at all. It was already explained to him that HEX is just a typical text representation of binary data:
https://community.st.com/s/question/0D53W00000e2PvaSAE/how-to-convert-hex-to-float-midlittle-endian-cdab-in-stm32cubeide
The "masking", which he is incapable of even explaining, seems to be this one:
https://datatracker.ietf.org/doc/html/rfc6455#section-5.3
A trivial algorithm with MOD and XOR operations. An ideal minor task for an absolute beginners like the author. One must learn the basics before making complex systems.
MM..1
sprintf %x
SVerm.3
SVerm.3Author
but I want to store in variable not to print...
MM..1
Description
The C library function int sprintf(char *str, const char *format, ...) sends formatted output to a string pointed to, by str.
Declaration
Following is the declaration for sprintf() function.
Parameters
  • str − This is the pointer to an array of char elements where the resulting C string is stored
Piranha
PiranhaBest answer
Principal III
May 30, 2021
SVerm.3
SVerm.3Author
thanks Sir, means a lot...
