Hi, acquiring analogue signal, using STM32 F3 DISCOVERY, I'd like to be able to read the values on the screen through TERA TERM, but I can't activate the serial port. Can you tell me what the problem is please?
IValo
Hi, Through STM32CubeIDE I'm acquiring analogue signal, using STM32 F3 DISCOVERY.
The converted values ​​are saved in a register, then I'd like to be able to read them on the screen through TERA TERM, but I can't activate the serial port. Can you tell me what the problem is please?
Your question basically indicates you failed, but lacks any details as to why.​
What pins and USART did you try to bring up?​
IValo
I 'd like to know if there's a way to create a file.txt, where it can save the values acquiring, without using USART
