I use Cube IDE, I would like to insert directives for the compiler into the code, for different optimization of parts of the code. How to do it?
Options
‎2022-11-28 1:24 AM
Options
‎2022-11-29 4:23 AM
The underlying compiler is gcc, so check the docs https://gcc.gnu.org/onlinedocs/gcc/Function-Specific-Option-Pragmas.html.
Basically, something like
#pragma GCC push_options
#pragma GCC optimize ("O0")
void my_function() {
#pragma GCC pop_options
will do the trick
hth
KnarfB
Options
‎2022-11-29 4:23 AM
will do the trick
hth
KnarfB
Options
‎2022-11-29 10:39 AM
Thanks a lot :grinning_face:
