file xxxx.elf does not exist how to solve this problem
I downloaded repository form github, but it not gonna work. I just open stm32cubeide few days ago and i try to learn it. Please help.
here is how it looks like, idk why there is simply nothing, and simply nothing i can do with it
Tesla DeLorean
Guru
March 19, 2025
Github of WHAT, from WHERE?
Perhaps you need to Import the project.
This doesn't show the Error you mention, which is likely because you need to rebuild the project for the .ELF for it to exist locally.
matitoAuthor
https://controllerstech.com/gps-neo-6m-with-stm32/
in the end of this is link to download the files.
after i click the button run, "show detail", there is written that the file xxxx.elf does not exist
Andrew Neil
So what, exactly, did you do between downloading the files, and clicking the 'Run' button?
Describe the steps you take in detail.
See: How to write your question to maximize your chances to find a solution.
You will need to import the code into CubeIDE, and then build it before you can run it.
Are you able to build and run any of ST's own examples?
I would strongly suggest that you follow some of ST's examples & tutorials first to learn the basics - before adding the complications of trying to import 3rd-party projects.
https://wiki.st.com/stm32mcu/wiki/STM32CubeIDE:Introduction_to_STM32CubeIDE
https://wiki.st.com/stm32mpu/wiki/How_to_get_started_with_STM32CubeIDE_from_scratch
https://www.youtube.com/watch?v=gL8OoS9E1rw&list=PLnMKNibPkDnFCosVVv98U5dCulE6T3Iy8
https://www.youtube.com/@stmicroelectronics/search?query=stm32cubeide
