Failed to execute MI command: target remote localhost: 3333
‎2019-10-23 7:21 PM
Hi, I’m using STM32CubeIDE 1.1.0 (Window) and bluepill STM32F103C8T6 but I met error when debugging:
Error in final launch sequence:
target remote localhost:3333
Error message from debugger back end:
localhost:3333: The system tried to join a drive to a directory on a joined drive.
Can anyone show me how to configure debug step by step?
Thanks!
STM32CubeIDE
STM32F1 Series
‎2019-10-24 4:58 AM
If you have a regular ST board there should not be a need to configure anything to launch a debug session after you've built the project.
Make sure the board is connected properly. Do you have STM32CubeProgrammer stand-alone? If so, can you connect to the board with it?
If you're still running into problems then please activate the gdb server log in the debug configuration (Debugger tab) and post it.
‎2019-10-24 6:29 PM
Hi, I could connect the board using STM32CubeProgrammer and I dont change anything in Debug Configuration. But when I click Debug, it showed the error like above. Here are some pictures that show the debug configuration:
Is that the problem related to my ST-Link?
Thanks.
‎2019-11-30 11:47 AM
I am having this exact same issue with STM32CubeIDE on OSX. I haven't changed any of the configurations for the debugger either.
‎2019-11-30 11:50 AM
I am using a nucleo32 board. The board is connected via usb and has worked with mbed just fine.
‎2019-12-02 11:30 PM
Hi, I found out that the problem is because of fake STM32 chip. If you use real STM32 chip or development board from manufacturer, STM32CubeIDE will work fine.
‎2020-05-14 7:01 AM
Fake maybe ONE of the reasons. Certainly not the only reason..... I have the problem with a NEW Nucleo-64 STM32L476​
‎2021-06-21 10:49 AM
I had the same problem with the Discovery board
> check cable and try changing the port if it still exists then do the following steps, I solved by this way.
Download this ST-Link Utility from ST website as shown in figure
- Connect your device like discovery board to PC
- click on connect to the target, if it shows an error then click on a firmware update.
- again click on connect device, it will show the latest version or an older one, once click on update firmware.
- after updating once again click on connect the target it will connected and then try to debug from IDE
‎2022-06-13 4:22 AM
This worked for me, thanks.
I had actually switched to jlink using the ST-reflash utility and when I restored the ST-Link it was not getting detected in stm32cubeide. But these steps fixed the issue.
I am using a Nucleo F767ZI btw.
