2024-02-09 5:12 AM
In the past 2 days, I have an errorwhen I launch the debugger and it looks the issue comes from eclipse. When I launched the debuger, I have this error window.
I uninstalled CubeIDE, and installed it again (tried 3 different versions).
I can download the program and it works. The disassemblyis empty too.
Any idea to solvethis issue?
JJ
2024-03-01 6:51 AM
I get a similar error when I try to debug.
the disassembly is empty but if you launch the window again you can see the assembly code. The assembly code isn't highlighted green along with the c code. It used to track earlier.
Any ideas how to get this working will be greatly appreciated.
How can I see the error log?
2024-03-01 6:58 AM
I was able to find the error log.
It seems related to the serial wire viewer I am using to print Hello World.
I will appreciate if anyone can help explain the problem and suggest any solutions.
