2025-02-17 11:49 PM
Good morning,
we are working on a project using a 5 inch display (RVT50HQSNWC01-B) in the TouchGFX Designer environment. Simulation, code generation and code download to the MCU works.
Problems arise when moving to STM32CubeIDE. In this environment, carrying out the build (compilation + linker) of the application various errors are reported, and this even after generating the code via CubeMX.
It should be highlighted that by carrying out the same procedure (project creation in TouchGFX Designer + build in STM32CubeIDE) for an ST board (therefore not Riverdi), the errors do not appear and everything goes smoothly.
I look forward to your cordial response.
Thank you.
