different Build Configuration for different pinout version
carleslsregner
Is it ok to use different build configuations for different pinout version?
As you may have experienced, sometimes pcb version how the pinout. Sometimes another UART or TIMER is used in another pin etc,...
Saket_Om
Hello @carleslsregner
Yes, it is OK and often the best solution to use different build configurations for different PCB/pinout versions,
Saket_Om
Saket_Om
Saket_Om
Andrew Neil
Yes, as @Saket_Om said, that's fine.
In situations where Build Configurations are not sufficient, you might take a look at this...
