decompressing a file from zlib library
Hi all,
I have a small test project setup in STM32CubeIDE where an sd-card is interfaced with stm32h743 MCU. The program uses zlib library where it compresses the file from 3.2MB to 26KB. That's good but I cannot find a way to decompress this file on the PC (7zip or zip) nor with the inflate() function so I can write the decompress file on the sd-card. I have used the demo example which the zlib provides (zpipe.c).
The sd-card interfacing is all FATFS based so I can't use local file operation functions. I have replaced them with FATFS calls. Any help would be appreciated.
/* header files */
#include "main.h"
#include "fatfs.h"
#include "sdmmc.h"
#include "gpio.h"
#include "zlib.h"
#include <stdint.h>
#include <string.h>
#define CHUNK 16384
FATFS myfatfs;
FIL srcFil;
FIL destFIL;
DIR myDir;
FILINFO myFileInfo;
const char DirPath[] = "/ADC File Dir";
char filepath[_MAX_LFN];
char destFilePath[_MAX_LFN];
char decompfile[_MAX_LFN];
int def(char *source, char *dest, int level);
int inf(char *source, char *dest);
int main(void)
/* USER CODE BEGIN 1 */
/* USER CODE END 1 */
HAL_Init();
/* USER CODE BEGIN Init */
FRESULT fresMain;
/* USER CODE END Init */
SystemClock_Config();
/* USER CODE BEGIN SysInit */
/* USER CODE END SysInit */
MX_GPIO_Init();
MX_SDMMC1_SD_Init();
MX_FATFS_Init();
/* USER CODE BEGIN 2 */
if(f_mount(&myfatfs, (TCHAR const *) SDPath, 0) == FR_OK) {
// open directory
if(f_opendir(&myDir, DirPath) == FR_OK) {
// read first file name
if(f_readdir(&myDir, &myFileInfo) == FR_OK) {
// get file name
memset(filepath, 0, sizeof(filepath));
memset(destFilePath, 0, sizeof(destFilePath));
snprintf(filepath, sizeof(filepath), "%s/%s", DirPath, (char *) myFileInfo.fname);
snprintf(destFilePath, sizeof(destFilePath), "%s/compress.z", DirPath);
// execute the compression method
def(filepath, destFilePath, Z_DEFAULT_COMPRESSION);
// close both files
fresMain = f_close(&srcFil);
fresMain = f_close(&destFIL);
snprintf(decompfile, sizeof(decompfile), "%s/decomp", DirPath);
inf(destFilePath, decompfile);
if(f_closedir(&myDir) == FR_OK) {
// dismount device
f_mount(0, "", 0);
/* USER CODE END 2 */
/* Infinite loop */
/* USER CODE BEGIN WHILE */
while (1)
/* USER CODE END WHILE */
/* USER CODE BEGIN 3 */
/* USER CODE END 3 */
/* Compress from file source to file dest until EOF on source.
def() returns Z_OK on success, Z_MEM_ERROR if memory could not be
allocated for processing, Z_STREAM_ERROR if an invalid compression
level is supplied, Z_VERSION_ERROR if the version of zlib.h and the
version of the library linked do not match, or Z_ERRNO if there is
an error reading or writing the files. */
int ret, flush;
unsigned have;
z_stream strm;
unsigned char in[CHUNK];
unsigned char out[CHUNK];
FRESULT fres = FR_OK;
uint32_t bw = 0U;
uint32_t srcPtr = 0U;
uint32_t destPtr = 0U;
/* allocate deflate state */
strm.zalloc = Z_NULL;
strm.zfree = Z_NULL;
strm.opaque = Z_NULL;
ret = deflateInit(&strm, level);
if (ret != Z_OK)
return ret;
/* compress until end of file */
do {
fres = f_open(&srcFil, source, FA_OPEN_EXISTING | FA_READ);
fres = f_read(&srcFil, in, CHUNK, &strm.avail_in);
// strm.avail_in = fread(in, 1, CHUNK, source);
// if (ferror(source)) {
// (void)deflateEnd(&strm);
// return Z_ERRNO;
if(fres != FR_OK) {
return Z_ERRNO;
} else if(fres == FR_OK) {
// move src pointer
srcPtr += CHUNK;
if(f_lseek(&srcFil, srcPtr) == FR_OK) {
fres = f_close(&srcFil);
//flush = feof(source) ? Z_FINISH : Z_NO_FLUSH;
flush = f_eof(&srcFil) ? Z_FINISH : Z_NO_FLUSH;
strm.next_in = in;
/* run deflate() on input until output buffer not full, finish
compression if all of source has been read in */
do {
strm.avail_out = CHUNK;
strm.next_out = out;
ret = deflate(&strm, flush); /* no bad return value */
assert(ret != Z_STREAM_ERROR); /* state not clobbered */
have = CHUNK - strm.avail_out;
fres = f_open(&destFIL, dest, FA_OPEN_ALWAYS | FA_WRITE);
fres = f_write(&destFIL, out, have, (UINT *)&bw);
if((bw != have) || (fres != FR_OK)) {
return Z_ERRNO;
destPtr += have;
if(f_lseek(&destFIL, destPtr) == FR_OK) {
fres = f_close(&destFIL);
// if (fwrite(out, 1, have, dest) != have || ferror(dest)) {
// return Z_ERRNO;
} while (strm.avail_out == 0);
assert(strm.avail_in == 0); /* all input will be used */
/* done when last data in file processed */
} while (flush != Z_FINISH);
assert(ret == Z_STREAM_END); /* stream will be complete */
/* clean up and return */
return Z_OK;
/* Decompress from file source to file dest until stream ends or EOF.
inf() returns Z_OK on success, Z_MEM_ERROR if memory could not be
allocated for processing, Z_DATA_ERROR if the deflate data is
invalid or incomplete, Z_VERSION_ERROR if the version of zlib.h and
the version of the library linked do not match, or Z_ERRNO if there
is an error reading or writing the files. */
int ret;
unsigned have;
z_stream strm;
uint32_t bw = 0U;
/* allocate inflate state */
strm.avail_in = 0;
strm.next_in = Z_NULL;
ret = inflateInit(&strm);
if (ret != Z_OK)
return ret;
/* decompress until deflate stream ends or end of file */
do {
if(fres != FR_OK) {
(void)inflateEnd(&strm);
return Z_ERRNO;
// move src pointer
srcPtr += CHUNK;
// (void)inflateEnd(&strm);
// return Z_ERRNO;
if (strm.avail_in == 0)
break;
strm.next_in = in;
/* run inflate() on input until output buffer not full */
do {
ret = inflate(&strm, Z_NO_FLUSH);
switch (ret) {
case Z_NEED_DICT:
ret = Z_DATA_ERROR; /* and fall through */
case Z_DATA_ERROR:
case Z_MEM_ERROR:
return ret;
return Z_ERRNO;
destPtr += have;
// return Z_ERRNO;
/* done when inflate() says it's done */
} while (ret != Z_STREAM_END);
return ret == Z_STREAM_END ? Z_OK : Z_DATA_ERROR;
}I wasn't sure of what would be the extension of the compressed file so I've added ".z" at the end which the windows do recognise as a compressed file but 7zip cannot decompress. When using the inflate() function it returns Z_DATA_ERROR (-3)
