Cannot Build imported stm32 project
‎2024-01-13 11:17 AM
I have imported a stm32 project from Git Hub that was there from 2 years ago to my stm32cudeide but when I try to build using internal builder: I get this error message:
Info: Internal Builder is used for build
arm-none-eabi-gcc "..\\..\\..\\..\\..\\..\\..\\..\\Drivers\\BSP\\X-NUCLEO-IHMxx\\x_nucleo_ihmxx.c" -mcpu=cortex-m4 -std=gnu11 -g3 -DUSE_HAL_DRIVER -DSTM32F401xE -DUSE_STM32F4XX_NUCLEO -DNUCLEO_F401RE -DSTM32F401RETx -DSTM32 -DSTM32F4 -DDEBUG -c -I../../../Inc -I../../../../../../../../Drivers/BSP/STM32F4xx-Nucleo -I../../../../../../../../Drivers/BSP/X-NUCLEO-IHMxx -I../../../../../../../../Drivers/BSP/Components/Common -I../../../../../../../../Drivers/BSP/Components/l6474 -I../../../../../../../../Drivers/CMSIS/Include -I../../../../../../../../Drivers/CMSIS/Device/ST/STM32F4xx/Include -I../../../../../../../../Drivers/STM32F4xx_HAL_Driver/Inc -O0 -ffunction-sections -Wall -fstack-usage -mfpu=fpv4-sp-d16 -mfloat-abi=hard -mthumb -o "Drivers\\BSP\\X-NUCLEO-IHMxx\\x_nucleo_ihmxx.o"
Cannot run program "arm-none-eabi-gcc": The directory name is invalid.
and using external builder:
5:00:36 **** Incremental Build of configuration Debug for project STM32F401RE-Nucleo ****
make all
15:46:32 **** Build of configuration Debug for project STM32F401RE-Nucleo ****
make all
Cannot run program "make": Code 0x10b: The directory name is invalid.
I don't know how to tackle this problem. Can someone help me with regards to this issue?
STM32CubeIDE
‎2024-01-24 04:02 PM
Hi Pavel and Semer,
After a lot of debugging and trying to figure out why my project wasnt building .I built a simple to project and realised it has nothing to do with the builder being used or the toolchain. It was actually funny. I realised it might be a path issue. Basically, some of the files that it was trying to build had a path that was very lengthy, so i reduced the folders name length and voila it worked. So luckily i was able to find my own solution. Thanks for all the help @Pavel A. and @Semer CHERNI.
‎2024-01-13 11:34 AM
Well, both internal and external builders fail with same error, so this is objective. Check in the project (or workspace) properties which toolchain is used. Is an old toolchain selected, which is no longer installed? If so, install this older toolchain (preferred) or try to jump ahead and choose a toolchain that is available.
Try to reinstall CubeIDE (again, the same version that you've used then, is preferred).
‎2024-01-13 07:11 PM
I'm still getting the same problem after trying that. The thing is the project is not mine so i don't know which version ide was used back then when it was made.
‎2024-01-14 07:51 AM
Can you post a screenshot of the toolchain selection in your project?
‎2024-01-14 08:21 AM
This is the githbub repo im trying to import: Edukit_Rotary_Inverted_Pendulum_Project/Edukit_Rotary_Inverted_Pendulum_Project at main · wjkaiser/Edukit_Rotary_Inverted_Pendulum_Project (github.com)
‎2024-01-15 02:09 AM
Hello @aelgammal
Could you try to make the build using the "GNU Tools for STM32(11.3.rev1) toolchain.
KR,
Semer.
‎2024-01-15 02:25 PM
Thank you for the reply. I tried that and still getting the same issue.
Amro
‎2024-01-15 02:42 PM - edited ‎2024-01-15 02:53 PM
Still get "Cannot run program "arm-none-eabi-gcc": The directory name is invalid" ?
Have you imported this SW4STM project into CubeIDE?
‎2024-01-15 02:45 PM
yup same exact issue for both internal and external builder
‎2024-01-16 08:09 AM - edited ‎2024-01-16 08:10 AM
The message means that the builder cannot find the gcc compiler. Either CubeIDE setup is broken or the project is broken too badly. Maybe the author of that github project would be able to port his work from SW4STM to CubeIDE - try motivate them?
![](/skins/images/6C9701F1F0456C4A3C184AC0BAE062DD/responsive_peak/images/icon_anonymous_message.png)
