can i implement ntp,http,hhtps and mqtt protocol using stm32F413ZHT6 in stm32cubeide
STAHI.1
Does the F413 even have support for Ethernet? Where would that connection come from? Cellular Modem, WiFi?
You can likely find a TCP/IP stack with support of assorted protocols. Commercial offerings likely to have a richer set of examples and support.
STAHI.1
in my project i use stm32F413ZHT6+w5500
mattias norlander
Not something that is officially supported in the Cube ecosystem.
w5500 seem to have SPI interface...
I think this setup will imply a lot of work without much support.
But if you are lucky maybe you can google and find some examples that already work well.
