Build Error - QuadSPI and FreeRTOS
2023-09-25 12:49 AM
I use Riverdi RVT70HSSNWC00-B STM32 based board. I got project from my colleague to continue working on it. I succesfully imported it and also project build worked, but always after some time I am getting same errors. It begins with library "tmk.h" no such file or directory error. I tried to link some paths to the file, if this problem dissappears I will get another QuadSPI and FreeRTOS error which shows up multiple declaration issues.
You can download the project here:
STM32CubeIDE
STM32CubeMX
2023-10-06 7:44 AM
Hello @MartinGinter
Based on errors mentioned in the screenshot, the compiler couldn't locate the source file. You should verify the include path.
