ADC Returning "0" zeros
Miha
Hello.
I have a problem with my ADC readings. I use Nucleo 64 with SM32G474 and ADC1 Channel 6. Pin coresponds to A5, Arduino compatible pin on board. No matter what i do, change adc or channel, i get 0 as an output. I use comands
MX_GPIO_Init();
MX_ADC2_Init();
HAL_ADC_Start_IT(&hadc1);
I have ADC1,2 global interupts enabled in CubeMX, my HAL_ADC_ConvCpltCallback are geting
called (i checked with breakpoints). My while is running, program except ADC works normaly,
GPIOs work. Enable regular conversions i have DISABLED, so i use software calls for ADC.
Scan Converscion and Continious Conversion i have both DISABLED. I tried almost everything.
No matter what i do HAL_ADC_GetValue() always returns me 0.
Mahmoud Ben Romdhane
Hello @Miha ,
First let me thank you for posting and welcome to the ST Community.
I advise you to consult this Wiki and this Post
It explains what ADC is and how to use it through an example.
Thanks.
Mahmoud.
