2025-07-21 4:41 AM - edited 2025-07-22 1:12 AM
I’m currently developing a template to help developers debug code located at address 0x8011000 using VSCode.
So far, I haven’t had any success getting the debugger to work properly.
The .elf file itself is fine, when I flash it using STM32CubeProgrammer and enable "Run after programming", the code executes as expected.
I’ve tried multiple solutions, including suggestions from ChatGPT, but nothing has worked yet.
2025-07-22 1:15 AM - edited 2025-07-22 1:20 AM
Got it to work, in case someone has a similar issue:
In my case Reset_Handler is defined in startup_stm32g474xx.s
launch.json
"version": "0.2.0",
"configurations": [
"name": "Debug UserApp at an offset (no full reset)",
"type": "cortex-debug",
"request": "launch",
"servertype": "stlink", // you're using ST-LINK GDB server, not openocd
"executable": "build/Debug/${workspaceFolderBasename}.elf",
"device": "STM32G474RE",
"gdbPath": "arm-none-eabi-gdb",
"runToEntryPoint": "Reset_Handler",
"postLaunchCommands": [
"monitor halt",
"break main"
"overrideLaunchCommands": [
"load"
"showDevDebugOutput": "raw"
}tasks.json
"version": "2.0.0",
"tasks": [
"label": "flash-userapp",
"type": "shell",
"command": "STM32_Programmer_CLI",
"args": [
"-c", "port=SWD",
"-w", "build/Debug/${workspaceFolderBasename}.elf", // or .hex or .bin
"-rst"
"problemMatcher": []
2025-07-21 10:43 PM
Not sure to understand what you are tryi.g to do here. Please be explicit more. Maybe a chance to get help then.
launch.json
"version": "0.2.0",
"configurations": [
"monitor halt",
"break main"
"load"
}tasks.json
"version": "2.0.0",
"tasks": [
"type": "shell",
"args": [
"-c", "port=SWD",
"-rst"
2025-07-22 1:16 AM - edited 2025-07-22 1:25 AM
I changpticed it for you @Cartu38 OpenDev , i was tired and not good articulating my problem
2025-07-23 12:17 AM
Thanks for sharing.
I note you are not using latest extension set proposal : https://community.st.com/t5/stm32cube-for-visual-studio-code/new-stm32cube-for-visual-studio-code-extenstion-released-3-5-1/td-p/819484
2025-07-23 5:13 AM
good catch
