STM32F407VGTx_FLASH.ld always corrupted when is generated by CubeMX for VS Code
deathka
It seems that the linker file is always corrupted when is generated by CubeMX for VS Code. I have done a workaround if needed.
Beste regards,
Andrew Neil
In what way(s), exactly, does it seem "corrupted"?
Please post an example and the associated .ioc file.
What versions of the tools are you using, and on what platform (with version)?
How to write your question to maximize your chances to find a solution
