Custom install path breaking build
‎2023-11-28 3:22 AM
I've installed using the path
"C:\ST\STM32CubeProgrammer\STM32CubeProgrammer\bin\STM32TrustedPackageCreator_CLI.exe"
and modified the scripts as directed.
e.g.
set stm32tpccli="C:\ST\STM32CubeProgrammer\STM32CubeProgrammer\bin\STM32TrustedPackageCreator_CLI.exe"
I'm getting a postbuild failure, because it is still seeking in the default path.
Generated by sh
../postbuild.sh: line 65: C:\Program Files\STMicroelectronics\STM32Cube\STM32CubeProgrammer\bin\STM32TrustedPackageCreator_CLI.exe: not found
I've searched both install and repository folders for mentions of the default path, but not found the problem.
Is the only solution to reinstall using the default path?
‎2023-11-28 6:41 AM
Spotted it!
A simple cut & pasting error.
‎2023-11-28 6:20 AM
Hello Alex,
I'm not sure what you have done exactly.
The postbuild.sh is sourcing the env.sh located in ROT_Provisioning directory.
If you modify this env.sh it should be taken into account.
Best regards
Jocelyn
‎2023-11-28 6:30 AM
I have this after I've modified the Cube Programmer path, but it is still looking in 'Program Files':
# General
#Configure tools installation path
if [ "$OS" == "Windows_NT" ]; then
stm32programmercli="C:\ST\STM32CubeProgrammer\STM32CubeProgrammer\bin\STM32TrustedPackageCreator_CLI.exe"
else
#stm32programmercli_path=~/STMicroelectronics/STM32Cube/STM32CubeProgrammer/bin/
PATH=$stm32programmercli_path:$PATH
stm32programmercli="STM32_Programmer_CLI"
stm32tpccli="STM32TrustedPackageCreator_CLI"
fi
‎2023-11-28 6:41 AM
Spotted it!
