2024-12-24 2:15 PM
I am getting a strange warning on IDE 1.17 after upgrading that I was not getting before
bin/ld.exe: warning: PE-28.elf has a LOAD segment with RWX permissions
I have not modified the Load file at all. It did not show up before, I can go back to the previous version and I do not get the warning. What could be causing this?
2024-12-24 2:24 PM
Many other posts about it. This one explains it well.
Solved: elf has a LOAD segment with RWX permissions when u... - STMicroelectronics Community
Other threads:
Solved: STM32CubeIDE 1.15.0: elf has a LOAD segment with R... - STMicroelectronics Community
STM32CuebIDE Issue 169316: “elf has a LOAD segment... - STMicroelectronics Community
2024-12-24 2:24 PM
Other threads:
2024-12-24 2:58 PM
Thank you.
