We are pleased to announce that the release 6.14.0 of STM32CubeMX is available.
What is new in 6.14.0:
- Added the support for the STM32WBA6xxx microcontrollers and:
- Added the support for USBX multi-instance
- Added the support for the memory management tool (MMT)
- Added the support for the STM32WBA65I-DK1 Discovery kit and NUCLEO-WBA65RI Nucleo board
- Deployed the Start From Board feature on the NUCLEO-WBA65RI
- Improved the Power Delivery (USB PD) functionality for STM32H7Rx/7Sx and STM32N6 microcontrollers by upgrading the USB PD library core to v5.3.0
- Adapted STM32CubeMX user interface to allow the user to:
- Access the Compare Projects utility from the home page and compare two existing projects
- Compare two existing projects without save down
- Improved the build process with CMake
- Update the RIF panels to indicate the peripherals that are not supported by STM32MP2 products.
- Removed the Secure Manager boot path
Main fixed issues in 6.14.0:
Refer to the STM32 microcontroller wiki at:
https://wiki.st.com/stm32mcu/wiki/Category:STM32CubeMX_errata
Known problems and limitations in 6.14.0:
How to get STM32CubeMX 6.14.0:
- Under this link
- Or update your current installation of STM32CubeMX using: Help > Check for Updates
