connection proxy error and no STM32 In DFU mode connected
amr5
hi guys i am trying to use  STM32MP135x-DK board with STM32CubeProgammer but after opening the software i got no internet connection  due to proxy setting and also no the program does not see any dfu device connected through usb .. can anyone help with this ?
amr5
i forgot to mention that i am using ubuntu 22.04
PatrickF
Hi @amr5
1) proxy message is likely because you have access to internet thru a proxy. Please check CubeProgrammer documentation to setup a proxy (there is a menu in 'Help -> Proxy settings)
2) no DFU is not normal.
- Did you connect the right USB to the board (it is not the STLINK one) ?
- Did the board in DFU mode (check BOOT pins)
Regards.
