TF-A boot fails for FSBL [Solved]
vfranchi
Hi all,
I updated my project from Morty (2.2) to Kirkstone (4.1). After doing the required fixes/updates on the recipes, I have problems booting the FSBL. I am using the Cube Programmer to flash the image. Below is the log:
STM32CubeProgrammer API v2.13.0 | Windows-64Bits
Read TSV File: C:\temp\stm32mp1-customized-img-kirkstone-alpha2\flashlayout_custom-os-image-debug\trusted\FlashLayout_nand-4-256_stm32mp153a-customized-img-cubemx-mx-trusted.tsv
Number of partitions: 11
UR connection mode is defined with the HWrst reset mode
Device Descriptor:
                        |_bLength                : 0x12
                        |_bDescriptorType        : 0x01
                        |_bcdUSB                 : 0x0200
                        |_bDeviceClass           : 0x00
                        |_bDeviceSubClass        : 0x00
                        |_bDeviceProtocol        : 0x00
                        |_bMaxPacketSize         : 0x40
                        |_idVendor               : 0x0483
                        |_idProduct              : 0xdf11
                        |_bcdDevice              : 0x0200
                        |_iManufacturer          : 0x01
                        |_iProduct               : 0x02
                        |_iSerialNumber          : 0x03
                        |_bNumConfigurations     : 0x01
Configuration Descriptor:
                        |_bLength                : 0x09
                        |_bDescriptorType        : 0x02
                        |_wTotalLength           : 0x48
                        |_bNumInterfaces         : 0x01
                        |_bConfigurationValue    : 0x01
                        |_iConfiguration         : 0x02
                        |_bmAttributes           : 0xc0
                        |_bMaxPower              : 0x01
Interface Descriptor Alternate Settings: 0x00
                        |_bLength                : 0x09
                        |_bDescriptorType        : 0x04
                        |_bInterfaceNumber       : 0x00
                        |_bAlternateSetting      : 0x00
                        |_bNumEndpoints          : 0x00
                        |_bInterfaceClass        : 0xfe
                        |_bInterfaceSubClass     : 0x01
                        |_bInterfaceProtocol     : 0x02
                        |_iInterface             : 0x06
Interface Descriptor Alternate Settings: 0x01
                        |_bLength                : 0x09
                        |_bAlternateSetting      : 0x01
                        |_iInterface             : 0x07
Interface Descriptor Alternate Settings: 0x02
                        |_bLength                : 0x09
                        |_bAlternateSetting      : 0x02
                        |_iInterface             : 0x08
Interface Descriptor Alternate Settings: 0x03
                        |_bLength                : 0x09
                        |_bAlternateSetting      : 0x03
                        |_iInterface             : 0x09
Interface Descriptor Alternate Settings: 0x04
                        |_bLength                : 0x09
                        |_bAlternateSetting      : 0x04
                        |_iInterface             : 0x0a
Interface Descriptor Alternate Settings: 0x05
                        |_bLength                : 0x09
                        |_bAlternateSetting      : 0x05
                        |_iInterface             : 0x0b
Functional Descriptor :
                        |_bLength                : 0x09
                        |_bDescriptorType        : 0x21
                        |_bmAttributes           : 0x0f
                        |_wDetachTimeOut         : 0xff
                        |_wTransferSize          : 0x0400
                        |_bcdDFUVersion          : 0x0110
USB speed   : High Speed (480MBit/s)
Manuf. ID   : STMicroelectronics
Product ID  : DFU in HS Mode @Device ID /0x500, @Revision ID /0x0000
SN          : 002A00253430510537333734
DFU protocol: 1.1
Board       : --
Device ID   : 0x0500
Start Embedded Flashing service
sending a set alternate setting request with index: 5
receiving packet
DFU status = 0
DFU State = 2
UpLoading data
DFU status = 0
DFU State = 2
sending a set alternate setting request with index: 1
Memory Programming ...
Opening and parsing file: tf-a-stm32mp153a-customized-img-cubemx-mx-usb.stm32
  File          : tf-a-stm32mp153a-customized-img-cubemx-mx-usb.stm32
  Partition ID  : 0x01
Download in Progress:
sending packet nbr: 0
DFU status = 0
DFU State = 2
Status: 0, State: 2
DFU status = 0
DFU State = 4
DFU status = 0
DFU State = 5
sending packet nbr: 1
DFU status = 0
DFU State = 5
Status: 0, State: 5
DFU status = 0
DFU State = 4
DFU status = 0
DFU State = 5
sending packet nbr: 2
DFU status = 0
DFU State = 5
Status: 0, State: 5
DFU status = 0
DFU State = 4
DFU status = 0
DFU State = 5
sending packet nbr: 3
DFU status = 0
DFU State = 5
Status: 0, State: 5
DFU status = 0
DFU State = 4
DFU status = 0
DFU State = 5
sending packet nbr: 4
DFU status = 0
DFU State = 5
Status: 0, State: 5
DFU status = 0
DFU State = 4
DFU status = 0
DFU State = 5
/* skipped */
sending packet nbr: 216
DFU status = 0
DFU State = 5
Status: 0, State: 5
DFU status = 0
DFU State = 4
DFU status = 0
DFU State = 5
sending packet nbr: 217
DFU status = 0
DFU State = 5
Status: 0, State: 5
DFU status = 0
DFU State = 4
DFU status = 0
DFU State = 5
sending packet nbr: 218
DFU status = 0
DFU State = 5
Status: 0, State: 5
DFU status = 0
DFU State = 4
DFU status = 0
DFU State = 5
sending packet nbr: 219
DFU status = 0
DFU State = 5
Status: 0, State: 5
DFU status = 0
DFU State = 4
DFU status = 0
DFU State = 5
sending packet nbr: 220
DFU status = 0
DFU State = 5
Status: 0, State: 5
DFU status = 0
DFU State = 4
DFU status = 0
DFU State = 5
Segment[0] downloaded successfully
File download complete
Time elapsed during download operation: 00:00:01.186
RUNNING Program ...
  PartID:      :0x01
DFU status = 0
DFU State = 5
sending a dfu end of download request
DFU status = 0
DFU State = 7
DFU status = 0
DFU State = 2
receiving packet
sending a clear status request
an error occured after sending the clear status request
Status: errUNKNOWN, State: dfuERROR
unable to switch the device to dfuIDLE state
Error: an error occured while uploading data from the virtual partition 0xF1
Error: Start operation failed at partition 0x01
Error: TSV flashing service failed
I checked the FAQ-STM32MP1-bring-up-troubleshooting-guide, but it didn't help.
I think the "unable to switch the device to dfuIDLE state" might be caused by the TF-A not executing properly rather than some device-host communication issue.
Some repo versions:
  • openembedded-core: yocto-4.0.2;
  • meta-openembedded: kirkstone;
  • meta-st-openstlinux/meta-st-stm32mp/meta-stm32mp-addons: kirkstone v22.07.27.
Does anyone have some idea how to proceed ?
Best Regards.
23 REPLIES 23
vfranchi
Please see the Uboot .dtb attached.
vfranchi
My CONFIG_MTDPARTS_NAND0_BOOT is using the default values.
Checking here the mtdparts sizes, they seem to match the partition table from the TSV.
STM32MP> mtdparts
device nand0 <nand0>, # parts = 9
 #: name                size            offset          mask_flags
 0: fsbl1               0x00080000      0x00000000      0
 1: fsbl2               0x00080000      0x00080000      0
 2: metadata1           0x00080000      0x00100000      0
 3: metadata2           0x00080000      0x00180000      0
 4: fip-a1              0x00400000      0x00200000      0
 5: fip-a2              0x00400000      0x00600000      0
 6: fip-b1              0x00400000      0x00a00000      0
 7: fip-b2              0x00400000      0x00e00000      0
 8: UBI                 0x1ee00000      0x01200000      0
active partition: nand0,0 - (fsbl1) 0x00080000 @ 0x00000000
defaults:
mtdids  : nand0=nand0
mtdparts: mtdparts=nand0:512k(fsbl1),512k(fsbl2),512k(metadata1),512k(metadata2),4m(fip-a1),4m(fip-a2),4m(fip-b1),4m(fip-b2),-(UBI)
Even though the partition definition looks fine, the error `Loading Environment from UBI... ubi0 error: vtbl_check: too large reserved_pebs 3049, good PEBs 1972` seems to point in something in this direction.
STM32MP> mtd list
List of MTD devices:
* nand0
  - type: NAND flash
  - block size: 0x40000 bytes
  - min I/O: 0x1000 bytes
  - OOB size: 224 bytes
  - OOB available: 118 bytes
  - ECC strength: 8 bits
  - ECC step size: 512 bytes
  - bitflip threshold: 6 bits
  - 0x000000000000-0x000020000000 : "nand0"
          - 0x000000000000-0x000000080000 : "fsbl1"
          - 0x000000080000-0x000000100000 : "fsbl2"
          - 0x000000100000-0x000000180000 : "metadata1"
          - 0x000000180000-0x000000200000 : "metadata2"
          - 0x000000200000-0x000000600000 : "fip-a1"
          - 0x000000600000-0x000000a00000 : "fip-a2"
          - 0x000000a00000-0x000000e00000 : "fip-b1"
          - 0x000000e00000-0x000001200000 : "fip-b2"
          - 0x000001200000-0x000020000000 : "UBI"
vfranchi
Hi @Kevin HUBER​ and @Community member​.
The booting partition problem is solved.
The fix was to add a node for fmc_pins_mx, fmc, uart7_pins_mx and a sub-node for nand-controller and nand with the setup below on the UBoot dtsi file.
u-boot,dm-pre-reloc;
Thank you both for your support.
Great ! Thanks @Vinícius Franchini​ for the feedback !
Olivier GALLIEN
