Shared memory access from the A7’s linux user space.
2020-02-14 10:26 AM
What is the best mechanism to access shared memory from the A7’s linux user space? I have tried using mmap and was successful at reading shared memory; however, I get memory exceptions when attempting to write. Could it be that I can only write to this memory in kernel space?
I can find documentation for the M4 processor and how to define shared memory in linker script. No luck with linux doc's other than “remoteproc�? and “rpmsg�? documentation, neither give clear instruction on how this is done.
Could you please refer me to some documentation that could help me get a better understanding on how this is done.
Thanks in advance!
- Labels:
STM32MP15 Lines
2020-02-16 11:38 PM
did you find this https://wiki.st.com/stm32mpu/wiki/Exchanging_buffers_with_the_coprocessor ?
and more specifically this example: https://wiki.st.com/stm32mpu/wiki/How_to_exchange_large_data_buffers_with_the_coprocessor_-_example
2020-02-17 2:23 PM
Patrick,
Thanks, this was great help! So is the answer to my question is to use DMA to access memory on the A7's side of the shared memory, ie dma_alloc_writecombine?
I need to get a better understanding of DMA and Cache Coherence, so I guess it's time to do that. I think using rpsmg-sdb-mod is the best approach in the long run: however, I also would like to get an understanding how the shared memory actually works.
Please let me know if I'm on the correct track here,
Thanks for your help!
John
