Please tell me about what "st-image-xxxxx" parameter means.
HMasu.1
Senior
I want to know what "st-image-xxxxx" parameter mean.
Especially, I want to know what name of xxxxx (for example "weston") means.
Is the name of xxxxx related to the name of some config file?
For example, if I changed the name of xxxxx to any name from weston, Are output files by bitabake influenced?
​Best Regards,
H. Masuda.
KnarfB
Principal III
Its the name of the recipe file in layers/meta-st-openstlinux/recipes-st/images/. So you might look up the recipe and see what else is possible or change the recipe according to your needs (Best done in your own layer).
2 REPLIES 2
KnarfB
Principal III
HMasu.1
Senior
Hi @KnarfB​
Thank you for your reply.
I understood very well.
So, when we create our own machine, Should we create our own layer(meta-***), and create recipe file in our own layer instead of using "weston"?
H. Masuda
