I have a stm32mp135F-DK and I am attempting to do some GPIO control. My question is where can I find the mapping of libgpiod chip/line mapping to physical pin. I am particularly interested in the mapping to the CN8 pins as I will be wanting to read/write signals coming from external sources. I have looked at the toggle_led.sh script and see that LD7 (green LED, PA14) is mapped to gpiochip0 line 14. One note is when I attempt to run this I get a Device/Resource is busy and when I run gpioinfo
gpiochip0 - 16 lines:
line 0: unnamed unused input active-high
line 1: unnamed kernel input active-high [used]
line 2: unnamed kernel input active-high [used]
line 3: unnamed kernel input active-high [used]
line 4: unnamed unused input active-high
line 5: unnamed unused input active-high
line 6: unnamed kernel input active-high [used]
line 7: unnamed unused input active-high
line 8: unnamed unused input active-high
line 9: unnamed kernel input active-high [used]
line 10: unnamed unused input active-high
line 11: unnamed unused input active-high
line 12: unnamed kernel input active-high [used]
line 13: unnamed "User-PA13" input active-low [used pull-up]
line 14: unnamed "blue:heartbeat" output active-low [used]
line 15: unnamed kernel input active-high [used]
gpiochip1 - 16 lines:
line 1: unnamed unused input active-high
line 4: unnamed kernel input active-high [used]
line 7: unnamed kernel input active-high [used]
line 8: unnamed kernel input active-high [used]
line 11: unnamed kernel input active-high [used]
line 13: unnamed unused input active-high
line 14: unnamed kernel input active-high [used]
gpiochip2 - 16 lines:
line 2: unnamed unused input active-high
line 3: unnamed unused input active-high
line 5: unnamed kernel input active-high [used]
line 10: unnamed kernel input active-high [used]
line 14: unnamed unused input active-high
line 15: unnamed unused input active-high
gpiochip3 - 16 lines:
line 0: unnamed kernel input active-high [used]
gpiochip4 - 16 lines:
line 6: unnamed unused input active-high
line 12: unnamed "panel-backlight" output active-high [used]
line 13: unnamed kernel input active-high [used]
gpiochip5 - 16 lines:
line 5: unnamed "interrupt" input active-high [used]
line 9: unnamed unused input active-high
gpiochip6 - 16 lines:
line 12: unnamed "interrupt" input active-high [used]
gpiochip7 - 15 lines:
line 2: unnamed "reset" output active-low [used]
line 4: unnamed "cd" input active-low [used pull-up]
gpiochip8 - 8 lines:
line 2: unnamed "interrupt" input active-high [used]
line 7: unnamed "enable" output active-high [used]
gpiochip9 - 16 lines:
line 3: unnamed "powerdown" output active-low [used]
line 4: unnamed "reset" output active-low [used]
line 9: unnamed "PHY reset" output active-low [used]
line 10: unnamed "PHY reset" output active-low [used]
line 11: unnamed "reset" output active-low [used]
line 12: unnamed unused input active-high
line 13: unnamed "shutdown" output active-high [used]
I don't know if this is due to the sample application running or not, see the attached picture.
Ultimately what I am looking for is when I read in the User manual that GPIO2 is pin 3, PH6, what gpiochip and line is this for example?
I imagine this will also clear up the other question of how do I know if I can access that pin or if for some reason another application or the kernel has the pin under control or if I can peek/poke it through gpioget and gpioset. Thanks in advance for your time.
