I need a roadmap for a STM32MP157C-DK2 project
IYetk
I am only a bit familiar with embedded linux. I will develop a demo project with STM32MP157C-DK2 with C language:
  • on M4 side, a sensor(BME280) and a vantilator (5v) are connected. Sensor is to read periodically and three numerical values( temp, humidity, pressure) will be send to A7 side
  • on A7 side a QT application will receive these three values and display them continuosly. Over this QT application, the user will be able to send on or off command for vantilator to M4.
  • M4 will receive this command and then will start or stop the vantilator.
At first, I should say, I played a bit with the board, did all the work which is called getting started with DK2 (https://wiki.st.com). Then I saw an article in bootlin about using BME280 sensor. But this article doesnt help me because it explains how to read the sensor from A7 (linux side). However I will read the sensor from M4 side.
Honestly, I don't know how my roadmap will be.
I mean where to start and which mechanisms, middlewares, package (dev or dist ?) , tools to use and which sources to read/look and what is next...
Could you please write me what I should do step by step in detail as much as possible ?
Could you please draw a roadmap for me ?
Olivier GALLIEN
Dupplicate of https://community.st.com/s/question/0D50X0000BBsS5MSQV/simple-stm32mp157cdk2-project-temp-sensor-5v-vantilator-on-m4-side-and-qt-interf-applica-on-a7-side
Close this post.
Olivier GALLIEN
Olivier GALLIEN
Close this post.
Olivier GALLIEN
