How to use the RTL8723BU in "Ecosystem V2.0.0"?
2020-11-08 5:47 PM
Hi All
If you create a distribution with RTL8723BU enabled in the Linux kernel and boot, you will see the error message below.
[ 30.102790] usb 2-1.2: 1f8: ff ff ff ff ff ff ff ff
[ 30.106213] usb 2-1.2: RTL8723BU rev E (SMIC) 1T1R, TX queues 3, WiFi=1, BT=1, GPS=0, HI PA=0
[ 30.118408] usb 2-1.2: RTL8723BU MAC: 34:c9:f0:8d:fc:72
[ 30.124300] usb 2-1.2: rtl8xxxu: Loading firmware rtlwifi/rtl8723bu_nic.bin
[ 30.131982] usb 2-1.2: Direct firmware load for rtlwifi/rtl8723bu_nic.bin failed with error -2
[ 30.141236] usb 2-1.2: request_firmware(rtlwifi/rtl8723bu_nic.bin) failed
[ 30.146569] usb 2-1.2: Fatal - failed to load firmware
[ 30.155477] rtl8xxxu: probe of 2-1.2:1.2 failed with error -11
If you search for the "rtl8723_nic.bin" file on the entire Linux system, it doesn't exist.
Is there any other way to use RTL8723BU in "Ecosystem V2.0.0"?
The method shown on the ST WiKi site is not a solution as it assumes that the device driver is loaded normally.
Any suggestions on how to solve the above problem would be appreciated.
Thanks and regards
Machilus
STM32MP15 Lines
2020-11-16 4:59 PM
Hi all.
I partially solved this problem.
It can be solved by taking the "rtl8723bu_nic.bin" file from the realtek git site and putting it in the "/lib/firmware/rtlwifi" folder.
However, when the Bluetooth and Wi-Fi functions are used together, one side of the Wi-Fi or Bluetooth is disconnected.
I'm looking for a solution to that problem. If you know anything that could be a hint, let me know.
Thanks and regards
Machilus
