How can I change device tree?
2020-12-10 10:16 PM
I understand that when I create my own machine, I can create device tree by following 2 method.
Method 1) Building device trees by Developer Package (separately from bitbake)
This method is described in following Wiki page.
https://wiki.st.com/stm32mpu/wiki/How_to_compile_the_device_tree_with_the_Developer_Package
Method 2) Building device trees by Distribution Package (included in bitbake)
https://wiki.st.com/stm32mpu/wiki/How_to_create_your_own_machine
In both of above two methods, I could create the device tree (.dtb file) successfully.
Now, I want to modify the "arch/arm/boot/dts/stm32mp157c.dtsi"
In Method1, I could create updated device tree (.dtb file) by modifying "arch/arm/boot/dts/stm32mp157c.dtsi".
However, In Method2, I could not create updated device tree (.dtb file) even though I modified "arch/arm/boot/dts/stm32mp157c.dtsi".
(The build was successful, but the changes were not reflected.)
Why does the difference between the two results occur?
How can I change device tree by modifying "arch/arm/boot/dts/stm32mp157c.dtsi" in Method 2?
Best Regards.
H. Masuda
- Labels:
STM32MP15 Lines
2020-12-12 3:18 PM
The stm32mp157c.dtsi and similar files are MPU specific. There should be no reasons to change them.
2020-12-14 8:25 AM
Hi @HMasu.1 ,
Indeed you should not have to change anything in stm32mp157c.dtsi, but you can override some properties inside your board level dts. ( likely generated by mx )
See DT structure : https://wiki.st.com/stm32mpu/wiki/STM32MP15_device_tree
In case Distribution/Method2 if by "arch/arm/boot/dts/stm32mp157c.dtsi" you mean same file and directory as Developer package it's wrong.
Distribution load and install source in its own folders.
see : https://wiki.st.com/stm32mpu/wiki/How_to_cross-compile_with_the_Distribution_Package
Olivier
2020-12-15 5:45 PM
Hi @KnarfB
Thank you for your reply.
I need to change usbh_ohci node and usbh_ehci node in stm32mp157c.dtsi to use USB on the original board we make.
Actually, in Method 1, I have succeeded in making USB available by modifying stm32mp157c.dtsi.
H. Masuda
2020-12-15 6:07 PM
Hi @Community member ,
(We have paid support from another company to use USB on the original board, which company has instructed us to change STM32MP157c.dtsi.)
Actually, in case Developer/Method1, I have succeeded in making USB available by modifying stm32mp157c.dtsi.
Is my understanding wrong?
In case Distribution/Method2, I understand that "arch / arm / boot / dts /stm32mp157c.dtsi" is not the same files and directories as the Developer Package.
In case Distribution/Method2, it is ".../tmp-glibc/work-shared/stm32mp1-***/kernel-source/arch/arm/boot/dts/stm32mp157c.dtsi" in my own load and install folder.
I'm sorry for the misleading description.
H Masuda.
2020-12-17 7:57 PM
I also want to know the relationship between "/layers/meta-st/meta-st-stm32mp-addons/mx//kernel/***.dts" and "/tmp-glibc/work-shared//kernel-source/arch/arm/boot/dts/***.dts".
Best Regards,
H. Masuda
