Hello, i'd like to use u-boot command sspi to send commands to a spi device with a custom protocol (not a memory). However I see that the command tries to read an ID as it is talking to a flash nor : unrecognized JEDEC id bytes: 00, 00, 00.
Lmoio.1
Looking at the code, i see file sf_probe.c with .id      = UCLASS_SPI_FLASH, that performs the id reading. How can i use stm32_spi.c with .id         = UCLASS_SPI, driver instead? and send "raw" spi data?
Lmoio.1
I added an alias for the spi and the command started working.
	aliases {
		serial0 = &uart4;
		serial1 = &usart3;
		spi1 = &spi1;
thank you
8 REPLIES 8
Olivier GALLIEN
Hi @Lmoio.1​ ,
Can you share your Device Tree and particularly the spi node ?
Thx
Olivier
Olivier GALLIEN
Lmoio.1
Hi @Community member​,
My spi node definition in the device tree is the following:
&spi1 {
	pinctrl-names = "default", "sleep";
	pinctrl-0 = <&spi1_pins_a>;
	pinctrl-1 = <&spi1_sleep_pins_a>;
	status = "okay";
	cs-gpios = <&gpioe 12 0>;
	spidev@0 {
                compatible = "stm32_spi";
                reg = <0>; /* CS #0 */
                spi-max-frequency = <10000000>;
I inlcude arch/arm/dts/stm32mp151.dtsi file so
spi1: spi@44004000 {
			#address-cells = <1>;
			#size-cells = <0>;
			compatible = "st,stm32h7-spi";
			reg = <0x44004000 0x400>;
			interrupts = <GIC_SPI 35 IRQ_TYPE_LEVEL_HIGH>;
			clocks = <&rcc SPI1_K>;
			resets = <&rcc SPI1_R>;
			dmas = <&dmamux1 37 0x400 0x01>,
			       <&dmamux1 38 0x400 0x01>;
			dma-names = "rx", "tx";
			power-domains = <&pd_core>;
			status = "disabled";
I modified spi command  to use the stm32 driver (but i'm not sure) instead of the spi_generic_drv driver:
	ret = spi_get_bus_and_cs(bus, cs, freq, mode, "stm32_spi",
				 str, &dev, &slave);
I added some print in the driver files, and when doing sspi 0:0.0 8 a, i see that it performs sf_probe.c probing function (spi_flash_std_probe and spi_flash_probe_slave) and gives:
I also tried disabling the spi flash driver, modifiying the defconfig with
CONFIG_ENV_IS_IN_SPI_FLASH=n
CONFIG_DM_SPI_FLASH=n
Now i see
spi_get_bus_and_cs: Binding new device 'generic_0:2', busnum=0, cs=2, driver=stm32_spi
But then it fails at line
priv->base = dev_remap_addr(dev);
in the stm32_spi.c file.
I worked some more on this issue and I noticed that inside spi-uclass.c file, the function ret = uclass_get_device_by_seq(UCLASS_SPI, busnum, &bus);
put in bus a udevice parent with name spi@58003000 that is the QSPI base address, is this a possible issue? How can I force to use spi@44004000 that is SPI1?
Olivier GALLIEN
Hi @Lmoio.1​ ,
Sorry for late reply.
Looking at your DT this is the comment I can do :
The node spidev@0 supposed to refer to the device connected on SPI.
The compatible = "stm32_spi"; supposed to refer to this device driver ... provider or in-house code.
In this case it refer to anything and anyway not to the stm32_spi driver.
compatible = "st,stm32h7-spi"; is the only and correct binding to call stm32_spi driver.
To be use SPI1 as raw I even wonder if you need to define a device node.
Did you try to remove it ?
Hope it help,
Olivier
Olivier GALLIEN
Lmoio.1
I tried command dm tree and noticed the following:
spi          0 [  ]  stm32_spi            |  |-- spi@44004000
spi          1 [ + ]  stm32_qspi           |  |-- spi@58003000
so I figured out that qspi was actually enabled. I disabled it in the device tree and now I don't see its entry anymore. However there is no "+" on the spi entry.
Why does the spy not get probed?
I removed the node as you mentioned,
&spi1 {
   status = "okay";
now when i try sspi, i get
Invalid bus 0 (err=-19)
Are you able to use it somehow? Do you have a better idea if I need to send data to another stm32 mcu via spi during boot?
Lidia
Lmoio.1
	aliases {
		serial0 = &uart4;
		serial1 = &usart3;
		spi1 = &spi1;
thank you
Hi @Lmoio.1​ ,
Well spotted !
For reference for others could you please confirm the working spi DT node for this usage ?
Thanks,
Olivier
Olivier GALLIEN
Lmoio.1
This is the device tree configuration i used
&spi1 {
	u-boot,dm-spl;
	status = "okay";
	cs-gpios = <&gpioz 3 0>;
and i also reverted all modifications i did in the spi.c uboot command.
To summarize:
  • CONFIG_CMD_SPI=y in the defconfig
  • qspi disabled in the device tree
  • spi enabled and with alias in the device tree
  • using the right bus "sspi 1:0.0 32 a"
