RGB LCD does not display
ZLiu.3
My rgb lcd screen does not display。
My board is based on the STM32MP153AAA3 design, using a separate power supply.
This is my schematic diagram
0693W00000aIdJqQAK.pngThis is the timing of the LCD
0693W00000aIdKZQA0.png This is the LCD device tree
​This is some panel-simple driver code
0693W00000aIdKPQA0.pngHere are some boot logs
Looking forward to your response!
ZLiu.3
i have solved it.
The ltdc node has a problem:
&ltdc {
    pinctrl-names = "default", "sleep";
    status = "okay";
    pinctrl-0 = <&ltdc_pins_b>;
    pinctrl-1 = <&ltdc_pins_sleep_b>;
    port {
        #address-cells = <1>;
        #size-cells = <0>;
        ltdc_ep0_out: endpoint@0 {
            reg = <0>;
            remote-endpoint = <&rgb_8_panel_in>;
1 REPLY 1
ZLiu.3
i have solved it.
&ltdc {
    status = "okay";
    port {
        #size-cells = <0>;
            reg = <0>;
